KB86104
Published: August 22, 2016
PAC Display Runtime: Layered buttons with Visibility/Blink attributes don't always display proper text
Version affected: R9.5a
If you've configured buttons with Visibility/Blink attributes, and then layered them on top of each other so that only one button is visible at a time and different text is displayed when different actions occur, the appropriate text may not be displayed when its action occurs in Runtime. However, the appropriate text is displayed when you hover the mouse pointer over the button.
Other objects—such as rectangle objects—are not affected by this issue. So instead of using buttons in your project, try using a different type of object to display messages.
