KB86113
Published: August 30, 2016
When graphics overlap, PAC Display Runtime should perform the actions configured for the top-most graphic
Version affected: R9.5a
If you've configured graphic objects with Visibility/Blink attributes to perform some action (for example, to open a window or send a value), and then layered the objects on top of each other in PAC Display, when an operator in Runtime clicks the top-most object, its dynamic attributes aren't always performed. Instead, sometimes the dynamic attributes of an underlying graphic are performed.
