KB86121
Published: September 28, 2016
In groov, the licensing window appears on all browser instances after a trial timer expires and start trial has been selected
GROOV-AR1-BASE
GROOV-SVR-WIN-BASE
GROOV-AR1
GROOV-AR1-SNAP
GROOV-SVR-WIN
GROOV-SVR-WIN-SNAP
Problem affects versions: R2.0a and higher
If you're using the groov trial and the trial expires, when you refresh the page the license window pops up and expects you to either enter a license or choose "Start trial" again.
However, if you have more than one browser open with instances of groov, other browsers will re-connect but also pop up the license window. Even if you've already clicked "Start trial," you will have to click it again in the other browsers.
Click "Start trial" each time the license window appears.
