KB86130
Published: August 23, 2016
OptoScript fails to set breakpoints following a single line comment starting with //*
PAC Control Basic
PAC Control Professional
Version affected: R9.5a
Within an OptoScript block, you can't create a breakpoint for any line of code that follows a comment line starting with the characters //*
For example, this line of code would prevent you from setting a breakpoint on any line of the script block after this line:
IncrementVariable(nIndex);   //* This is actually a single line comment
You can tell the breakpoint isn't set, because the red dot (indicating a breakpoint) never appears in the script's left margin.
