KB86137
Published: August 29, 2016
PAC Display: Unable to configure string tables for Send String dynamic attribute command
Versions affected: R9.5a and Beta versions B9.5b builds 0001 through 0014
When you configure a Send String dynamic attribute, you can't select a string table element because the String Tag Selection dialog box doesn't include "String Table" in the Item Type window.
