KB86142
Published: September 2, 2016
Stopping a strategy while a chart holds a lock on a flag variable can make the controller unresponsive
SNAP-PAC-S1-FM
SNAP-PAC-R1-FM
SNAP-PAC-R1-B
SNAP-PAC-R2-FM
SOFTPAC
Versions affected: Firmware R8.1a and higher
Problem is fixed in version: PAC firmware R9.5d
If you stop a strategy while a chart holds a lock on a flag variable (by using the Flag Lock command), the flag variable is not released, which prevents any other chart from accessing the variable. This state can result in a loss of communications with the controller.
