KB86150
Published: August 24, 2016
Unexpected results when changing PID parameters in PAC Control Debug mode
SNAP-PAC-S1-FM
SNAP-PAC-R1-FM
SNAP-PAC-R1-B
SNAP-PAC-R2-FM
Versions affected: Firmware R9.5a and R9.5b
Problem is fixed in version: Firmware R9.5c
When using PAC Control in Debug mode, changes to PID parameters can cause unexpected results such as:
- Requested changes are not made
- Written values are incorrect
- Wrong PID parameters are changed
- Algorithm choice is changed
Note that this issue does not affect changes made to PID parameters when using PAC Control in Configure
mode.
Use a R9.4 version of controller firmware.
