KB86154
Published: October 5, 2023
OptoScript dialog in PAC Control is read-only while in Config mode
PAC Control Basic
PAC Control Professional
R9.5a to current (may affect earlier versions)
When you have the OptoScript dialog open in PAC Control Debug mode and transition to Config mode, the OptoScript dialog becomes read-only, and you are not able to modify the script.
If the OptoScript dialog is read-only while in Config mode, close the dialog and reopen it.
