KB86189
Published: September 22, 2016
Color changes made to original or duplicate groov gadget are applied to both gadgets
groov View running on:
- GROOV-AT1, GROOV-AT1-SNAP
R3.1a to R3.2b
R3.3a
In groov Build, if you duplicate an LED, Range Indicator, or Round Gauge gadget, any changes you make to either the original or duplicate gadget's color ranges are applied to both gadgets, until you save the project and switch to groov View and back.
After duplicating a gadget (or several gadgets), before editing them, save the project and switch to groov View and then back to groov Build.
