KB86202
Published: September 28, 2016
In groov View for iOS on an iPad Pro, once set, the "Handheld View" option may stick even if turned off
R2.42 and lower
R2.43
In groov View for iOS, once you have set the Handheld View, sometimes it continues to be displayed after you uncheck it.
Note: This issue seems to occur only on the iPad Pro. Regular iPads and iPad mini do not display this symptom.
Close and kill the app, and then restart it.
