KB86203
Published: September 28, 2016
In groov View for iOS on iPad, the display moves up when you return from changing app settings
R2.41
R2.43
In groov View for iOS on the iPad, if you tap the gear icon to change settings and then return to the app, the display moves up a bit each time.
Note: This issue seems to affect only the iPad. iPhones do not display this symptom.
Disconnect from groov and reconnect. If that doesn't work, close the app, kill it, and restart it.
