KB86206
Published: September 12, 2016
SoftPAC: Unable to communicate to MMP port via UDP
SOFTPAC
Versions affected: PAC firmware R9.5a through R9.5c
Problem is fixed in version: PAC firmware R9.5d
Note: This issue applies only to SoftPAC and UDP communications. It does not affect TCP communications.
PAC Manager, iPAC, and aPAC are unable to connect to SoftPAC's MMP port via UDP.
This issue prevents you from successfully performing actions such as:
  • Accessing the SoftPAC controller's Scratch Pad from another device (you'll get an error message);
  • Finding or discovering SoftPAC controllers (SoftPAC controller won't be listed in the results).
To communicate via UDP, use SoftPAC R9.4 or lower.
