KB86212
Published: September 12, 2016
SoftPAC: Multiple charts heavily accessing the same communcations handle can cause a -16 Bus Error
SOFTPAC
Versions affected: Firmware R9.5a through R9.5c
Problem is fixed in version: PAC firmware R9.5d
Note: This issue affects SoftPAC only.
When multiple charts in a strategy running on SoftPAC make fast, repeated calls to the same communication handle, the comm handle can accidentally close. Any chart trying to access the closed comm handle will stop running. This situation will also add a -16 "Bus Error" (communications error) record to the message queue.
Use SoftPAC version R9.4c or lower.
