KB86232
Published: September 27, 2016
Using Scale Window tool on a SuperTrend graphic may cause PAC Display Configurator to crash
Versions affected: R9.5b
Lower versions may be affected
Problem is fixed in version: R9.5c
PAC Display Configurator may crash when you use the Scale Window tool to resize a SuperTrend graphic. (The Scale Window tool is located in the Toolbox and looks like a window with a double-headed arrow through it.)
