KB86238
Published: September 14, 2016
E1/E2 Serial Optomux watchdog timeout does not work
Problem affects versions: Firmware R1.2a
Problem is fixed in version: Firmware R1.2b
If you use Optomux Command "D" (or command "m") with an E1 or E2 brain board, the watchdog timeout will not be triggered after the serial Optomux line has been silent for the configured amount of time.
