KB86257
Published: October 27, 2016
Cannot enable communication to mistic brain with quadrature digital input module configured
Versions affected: PAC firmware R9.4a through R9.5c
Problem is fixed in version: PAC firmware R9.5d
When you run a strategy that contains a mistic I/O unit with a configured quadrature digital input module, it is not possible to enable communication to the I/O unit.
No error messages are written to the controller's message queue to warn you of this issue; however, when you double-click the unit to inspect it, you can see that it's not enabled.
