KB86259
Published: August 1, 2017
SNAP PAC RESTful API: The value in a 1-element table may be returned as a key-value pair instead of as an array
SNAP-PAC-S1-FM
SNAP-PAC-R1-FM
SNAP-PAC-R1-B
SNAP-PAC-R2-FM
Versions affected: PAC firmware R9.5a through R9.5d
Problem is fixed in version: FW R9.5e
When using the SNAP PAC RESTful API to get the value in a 1-element table, if you add a slash ( / ) to the end of the request*, the controller may return the value formatted as a key-value pair. Instead, the controller should return the value formatted as an array.
For example, when a table has only one element, a request like this:
/device/strategy/tables/int32s/MyTable/
...may return the response as a key-value pair—like this:
value: 6
Instead, the response should be formatted as an array—like this:
6
Note: If you don't put the slash at the end of the request, the controller correctly formats the returned value.
*A request is a URL that follows the syntax for the SNAP PAC REST API. It's also known as an "endpoint."
