KB86301
Published: November 16, 2016
Opto iPAC/aPAC display analog input & output points as Unknown() when IO via Controller is selected
Problem affects versions: All versions
If you have edited a device to see I/O via Controller and then view an analog point on that device, Opto iPAC and Opto aPAC display "Unknown()" as the Type. The type should appear as "Analog Input" or "Analog Output."
