KB86330
Published: October 21, 2016
Using Internet Explorer with groov, changes to event notification message configuration are not saved
GROOV-AR1-BASE
GROOV-SVR-WIN-BASE
GROOV-AR1
GROOV-AR1-SNAP
GROOV-SVR-WIN
GROOV-SVR-WIN-SNAP
Problem affects versions: R3.0a to R3.2b
Problem is fixed in version: R3.3a
If you're using Internet Explorer with groov, when you configure tag events in Build, any changes you make to an event message body are not saved. This issue applies to both new and edited events.
This issue does not occur with other browsers.
Use a different browser, for example Firefox, Chrome, or Safari.
