KB86373
Published: January 4, 2017
BACnet/IP Integration Kit doesn't correctly return object names when queried by other BACnet/IP devices or host software
PAC-INT-BAC-IP
R9.4d; lower versions may also be affected
R9.4e
When the BACnet/IP Integration Kit (PAC-INT-BACNET-IP) is queried by other BACnet/IP devices or host software, the Kit correctly returns the values of the objects it reads, but the object names that it returns may be incorrect.
