KB86378
Published: December 3, 2025
On previously configured PID, Output field and drop-down list are empty
- PACCONTROLBAS (PAC Control Basic)
- PACCONTROLPRO (PAC Control Pro)
All versions
In PAC Control, when you open the Add PID Loop dialog box to view a previously configured PID loop, all configured fields should show the last saved values. With this issue, the Output field is blank, and when you click on the drop-down list next to the Output field to select an analog point, the list is blank.
Contact Product Support (support@opto22.com) for further assistance.
