KB86382
Published: January 26, 2017
Error in groov Build when importing Modbus tags containing Unicode characters
GROOV-AR1-BASE
GROOV-SVR-WIN-BASE
GROOV-AR1
GROOV-AR1-SNAP
GROOV-SVR-WIN
GROOV-SVR-WIN-SNAP
Problem affects versions: R2.3a through R3.3b
Problem is fixed in version: R3.4a
In groov Build, when you try to import Modbus tags containing unicode characters, you see the following error message: "An error occurred while trying to interpret and save your uploaded tags."
The tags are added to the database after a page refresh, but their names contain garbage characters. You can confirm this by refreshing the page and returning to the Configure Modbus Tags dialog box.
  1. Edit the Modbus tags CSV file in a text editor and rename any tags that contain unicode characters.
  2. Open the Configure Modbus Tags dialog box in groov Build.
  3. Delete all garbage tags.
  4. Reimport the unicode-free Modbus tags CSV file.
