KB86390
Published: August 1, 2017
Read Numeric Table From I/O Unit Memory Map: Elements 300–599 are a duplicate of
elements 0–299
SNAP-PAC-S1-FM
SNAP-PAC-R1-FM
SNAP-PAC-R1-B
SNAP-PAC-R2-FM
Problem was discovered in version: PAC firmware R9.5d (Lower versions may be affected)
Problem is fixed in version: FW R9.5e
When using the PAC Control command "Read Numeric Table From I/O Unit Memory Map," if you attempt to read more than 300 table elements at one time, elements 0 through 299 will be unique, but elements 300 through 599 will be duplicates of element 0 through 299.
Perform multiple table reads, requesting a maximum of 300 elements per read.
