KB86413
Published: March 14, 2017
POSTs to the SNAP PAC REST API may fail
Firmware for:
SNAP-PAC-S1-FM
SNAP-PAC-R1-FM
SNAP-PAC-R1-B
SNAP-PAC-R2-FM
Versions affected: FW R9.5a through R9.5d
If you send a POST request to a controller enabled for the SNAP PAC REST API, and the Content-Length field in the header is missing or is zero (that is, content-length: 0), the POST will fail.
Responses to the request can vary; for example, the controller may return an HTTP 400 or an HTTP 200 error message. In addition, some data in the controller may be corrupted, or the controller may perform a reset.
Be sure to include the Content-Length field in the request header, and make sure the Content-Length value is not zero.
