KB86433
Published: January 3, 2017
PAC Display Configurator: Save Project dialog box sometimes appears if you click No when prompted to "Continue opening the project?"
Versions affected: R9.5d
Problem is fixed in version: R9.6a
If PAC Display Configurator is configured to load the previous project on startup (File > Configurator Options) and you attempt to open a project from a previous version of PAC Display, the Save Project dialog box sometimes appears if you click No when prompted to "Continue opening the project?"
If you then click Yes on the Save Project dialog box, PAC Display crashes.
Click Cancel in the Save Project dialog box to avoid opening the project in PAC Display R9.5d and to prevent PAC Display from crashing.
Opto 22 has resolved the issue.
