KB86434
Published: February 27, 2017
SNAP PAC REST API: Controller should display a message after an SSL certificate is installed
- SNAP-PAC-S2, SNAP-PAC-S2-W
- SNAP-PAC-R1, SNAP-PAC-R1-FM, SNAP-PAC-R1-W, SNAP-PAC-R1-B
Versions affected: FW R9.5a through R9.5h
R10.0d
Note: This issue applies only to controllers enabled for the SNAP PAC REST API.
After you update an existing SSL certificate (https://<controller IP address>/admin/certs), the controller should display a message to tell you whether the update succeeded or failed (but it doesn't).
Controller should display a message after an SSL certificate is installed.
