KB86456
Published: January 25, 2017
In groov, invalid .idb.txt file causes controller name and tags to disappear
GROOV-AR1-BASE
GROOV-SVR-WIN-BASE
GROOV-AR1
GROOV-AR1-SNAP
GROOV-SVR-WIN
GROOV-SVR-WIN-SNAP
Problem affects versions: All versions
If you create a new Opto 22 controller device and select an invalid .idb.txt file (that is, a file that has the correct extension but is not a PAC Control strategy file), the device list will show a controller with no name.
If you update an existing controller with an invalid .idb.txt file, the name of the device and all its tags will disappear.
Make sure your .idb.txt file is a valid PAC Control strategy file.
