KB86466
Published: April 25, 2017
In groov Build, gadgets don't reflect deleted or changed Modbus tags until you refresh
GROOV-AR1-BASE
GROOV-SVR-WIN-BASE
GROOV-AR1
GROOV-AR1-SNAP
GROOV-SVR-WIN
GROOV-SVR-WIN-SNAP
Problem affects versions: R2.3a to R3.3b
Problem is fixed in version: R3.4a
Gadgets associated with dynamic Modbus tags that have been deleted don't show the no-tag icon in groov Build until you exit and re-enter Build. In older versions of groov, the no-tag icon does not appear at all.
Additionally, if you change a tag type, the change isn't reflected until you exit and re-enter Build.
In newer versions of groov, you can reload build, and the gadget will be updated.
