KB86474
Published: January 4, 2017
Passing negative numbers to GenerateReverseCrc16OnTable32 can cause the controller to reset
SNAP-PAC-S1-FM
SNAP-PAC-R1-FM
SNAP-PAC-R1-B
SNAP-PAC-R2-FM
SOFTPAC
Versions affected: PAC firmware: All versions through R9.5d
Problem is fixed in version: FW R9.5e
When using the GenerateReverseCrc16OnTable32 command, if you pass a negative number for the start index or number of elements, the controller may reset—or instead of resetting, it may return what looks like a valid result.
Either way, passing in a negative value should return an error status code.
Before calling the command, ensure that neither the start index nor the number of elements is a negative number.
