KB86480
Published: July 19, 2017
PAC Display: Exponential values are displayed with 3 digits in the exponent (instead of 2)
Versions affected: R9.5a through R9.6d
PAC Display Runtime displays three digit exponents (for example, 1.234 e003) when expressing Integer 32 and Integer 64 values in exponential notation. Instead, they should be displayed with only two digits in the exponent (for example, 1.234 e03).
Making this change ensures that exponential values have the same format as they did in PAC Display R9.4e and lower.
Note that float values in exponential notation were changed back to the two-exponent format in R9.6a.
