KB86484
Published: February 27, 2019
Controller may stop responding after user stops strategy
Firmware for:
SNAP-PAC-S1-FM
SNAP-PAC-R1-FM
SNAP-PAC-R1-B
SNAP-PAC-R2-FM
SoftPAC
All PAC Firmware versions through R10.0d
PAC firmware R10.0f
The controller may stop responding after you stop the strategy. This might happen if a chart in the strategy has locked an object (with the Flag Lock command) and did not unlock it (with the Flag Unlock command) before the strategy was stopped.
You can minimize the possibility of this happening by modifying strategy logic: when using the Flag Lock command, minimize the amount of time the object is locked (using the Flag Unlock command).
