KB86487
Published: February 8, 2017
Cannot control or configure I/O points with 32-bit PC-Based Direct I/O SDK
PC-Based Direct I/O SDK for PCI Adapter Cards
Versions affected: R6.0a and R6.0b
When using a 32-bit custom application that was originally created with the PC-Based Direct I/O SDK version R5.0b or lower, and then upgraded with the PC-Based Direct I/O SDK (versions R6.0a or R6.0b), the following issues can happen:
  • I/O points are always reported as on.
  • Outputs can not be configured or controlled.
