KB86500
Published: February 23, 2017
groov Data Store API may respond with 500 Internal Server Error when reading a table tag
GROOV-AR1-BASE
GROOV-SVR-WIN-BASE
GROOV-AR1
GROOV-AR1-SNAP
GROOV-SVR-WIN
GROOV-SVR-WIN-SNAP
Problem affects versions: R3.3a-R3.3b
Problem is fixed in version: R3.4a
In the groov Data Store API, you may receive a 500 Internal Server Error under either of these conditions:
- You read a tag that is a table but enter a count of 0 (/api/v1/data-store/read/{id}?count=0)
- You write to a tag that is a table but enter an index greater than the size of the table (/api/v1/data-store/write/{id}?value=1&index=999)
In both cases, you should receive a more explanatory error.
