KB86562
Published: February 20, 2017
PAC Display: Using mouse wheel causes table contents to roll out of table frame
Version affected: R9.6a
Problem is fixed in version: R9.6b
If a PAC Display window contains a table graphic, and you use your mouse wheel to move up and down in the window, the table's frame remains stationary, and the rows inside the table move with the movement of the mouse wheel.
This can make the rows seem to roll outside the table's frame.
Note that this issue happens when the mouse wheel is positioned over the window itself, and not when it's over a table.
