KB86572
Published: April 6, 2017
"get.src" and "get.scrport" Comm handle commands may return incorrect data when using UDP
SNAP-PAC-S1-FM
SNAP-PAC-R1-FM
SNAP-PAC-R1-B
SNAP-PAC-R2-FM
Versions affected: All versions of PAC firmware through R9.5d
Problem is fixed in version: FW R9.5e
Note: This issue affects only UDP communication handles.
When a strategy uses a UDP communication handle to send a "get.src" or "get.srcport" command with Send Communications Handle Command, the value returned for the source IP address and the source port may be invalid. (This issue does not happen with TCP comm handles.)
Use the "Get Number of Characters Waiting" command, and only if the number of characters is greater than zero, send the get.src command.
