KB86581
Published: August 20, 2020
Some I/O points show incorrect temperature unit (F/C) in report
- PACCONTROLBAS (PAC Control Basic)
- PACCONTROLPRO (PAC Control Professional)
All versions prior to R10.3b
R10.3b
In PAC Control, when you view or print a database report (File > View/Print > Database), some I/O points may show °C on an I/O unit configured for °F, or vice versa.
Set the temperature scale for the I/O unit first, then configure each point on that unit.
