KB86583
Published: March 7, 2017
PAC Display Runtime may crash if labels are set to display Integer 64 values as binary
Problem is fixed in version: R9.6c
If a label is configured to display an Integer 64 value in binary format, PAC Display Runtime may crash when the window that displays the label is loaded.
Display the value as decimal or hex.
