KB86584
Published: March 7, 2017
For some modules on a G4EB2, EtherNet/IP Configurator may incorrectly configure TPO and Pulsed Output
EtherNet/IP Configuration Software
Versions affected: All versions
Problem is fixed in version: R3.0q
When you configure TPO (Timed-proportional output) or Pulsed Output for modules on a G4EB2 I/O unit, EtherNet/IP Configurator retains the settings for Module 0, but TPO or Pulsed Output settings for any other module on the G4EB2 may be incorrect.
For G4EB2s, use PAC Control to configure TPO and Pulsed Output.
