KB86630
Published: August 1, 2017
Examining a local pointer within a subroutine causes hardware controllers to reset and software controllers to log an error
SNAP-PAC-S1-FM
SNAP-PAC-R1-FM
SNAP-PAC-R1-B
SNAP-PAC-R2-FM
Versions affected: PAC firmware R9.5a through R9.5d
Problem is fixed in version: FW R9.5e
If you step into a subroutine that has a local pointer object and then try to examine the pointer, the controller will reset.  If you try the same actions using PAC Sim or SoftPAC, the software controller will write a -16 (Bus) error to the queue.
