KB86654
Published: June 26, 2017
PAC Display Runtime crashes when opening a SuperTrend historical log file
Versions affected: R9.5a through R9.6d
Problem is fixed in version: R9.6e
When viewing SuperTrend historical log files in PAC Display Runtime, Runtime will crash if you click the active historical log file (that is, the file being logged to) and then click OK.
The issue occurs only when the "Keep File Open" option has been configured for the SuperTrend historical log file.
Disable the "Keep File Open" setting (SuperTrend Setup > Setup tab > Log to button > Keep File Open check box).
