KB86682
Published: April 19, 2017
PAC Display Configurator: Issues with dynamic attributes for charts
Versions affected: R9.6a, R9.6b, and R9.6c
Problem is fixed in version: R9.6d
If your PAC Display project has dynamic attributes configured for a chart, and then you upgrade to PAC Display R9.6a, R9.6b, or R9.6c, you can no longer access the chart's dynamic attributes in Configurator. Note that Runtime is not affected; you can still send and read values in Runtime.
Similarly, you won't be able to configure new dynamic attributes for charts,
because "Chart" is missing from the list of Item Types in the Tag
Selection dialog box (Dynamic Attributes > ? button).
Use PAC Display R9.5d or lower.
