KB86739
Published: June 26, 2017
PAC Display Configurator Pro may hang or crash when you replace the configured control engine
Versions affected: R9.5a through R9.6d
Problem is fixed in version: R9.6e
Note: This issue occurs only when a PAC Display Pro project has a remote OptoOPCServer configured (Configure > Control Engine(s) > Add > Primary Scanner).
If you try to change the project's control engine (Configure > Control Engine(s) > Replace), PAC Display Configurator Pro may hang or crash when you click OK in the Control Engine Properties dialog box.
