KB86741
Published: June 28, 2017
PAC Display Runtime Professional sometimes fails to start
Problem was discovered in version: R9.6d
Lower versions may be affected
Problem is fixed in version: R9.6e
Note: This issue happens only when a PAC Display Professional project has been configured with at least one user (Configure > Runtime > Security tab).
If you click the Exit Runtime button in PAC Display Runtime Pro instead of selecting a user name and entering a password, Runtime closes as expected. However, if you try to restart Runtime, sometimes Runtime won't reopen. No messages or warnings are displayed to explain why Runtime Pro won't start.
  1. Open Windows Task Manager.
  2. In Windows 8 and higher, click the Details tab.
    In Windows 7 and Vista, click the Processes tab.
  3. Find DisplayRpro.exe, and then right-click it.
  4. In the pop-up menu, click End Task, and then click End Process.
  5. Restart Runtime Pro.
