KB86752
Published: June 29, 2017
PAC Display: Graphic objects may not be updated when their window is larger than the primary monitor
Versions affected: All versions
Problem is fixed in version: R9.6e
When a window in a PAC Display project spans two or more monitors, the values assigned to graphic objects may not update during Runtime if the objects are positioned outside the dimensions of the primary monitor.
For example, if your primary monitor is 1920 pixels wide and the window in your project is 2400 pixels wide, graphic objects positioned in the outlying 480 pixels of the project window may not update during Runtime.
Use two or more windows to cover the height and width of the area where you want to display the graphic objects.
