KB86765
Published: March 14, 2018
groov View: Trend gadget displays yellow triangle; information box reports a "groov Box or Server cannot be reached" message
groov View running on:
- GROOV-AT1, GROOV-AT1-SNAP
R3.3a through R3.4c
R3.5a
When your groov project includes many trends (or several trends with long time periods—such as 5-year trends), eventually, newly created trends display a yellow triangle. When you click the triangle for details, the information box reports that the "groov Box or Server cannot be reached."
Looking in the logs will show communication errors that look like this:
2017-05-16T08:25:02+10:00 An exception occurred while handling /api/v0/data-logging/fetch-interactive
ERROR - com.opto22.groov.server.servlets.ApiServlet
2017-05-16T08:25:02+10:00 InteractiveDataFetchOperation - Received a non-200 response: 500
ERROR - com.allen_sauer.gwt.log.client.Log
2017-05-16T08:25:02+10:00 InteractiveBehaviorHandler(1)::onDataLogError - Something went sideways:
GENERIC ERROR - com.allen_sauer.gwt.log.client.Log
2017-05-16T08:25:02+10:00 InteractiveBehaviorHandler(1) - Initial series load failed due to a network error:
...as well as errors with the background scanning service that look like this:
2017-05-16T08:20:44+10:00 An IOException occurred while trying to retrieve a buffer for {:tagId 32, :index 0, :retain 1051200, :update 60, :interactive true}
ERROR - com.opto22.groov.server.datalogging.BackgroundScanningService
2017-05-16T08:20:44+10:00 java.io.IOException: Map failed
Use a smaller number of trends in your project, or shorten the time periods used in the trends.
