KB86775
Published: June 1, 2017
groov may fail to close network sockets on Modbus connection errors
GROOV-AR1-BASE
GROOV-SVR-WIN-BASE
GROOV-AR1
GROOV-AR1-SNAP
GROOV-SVR-WIN
GROOV-SVR-WIN-SNAP
Problem affects versions: R2.3a to R3.4a
Problem is fixed in version: R3.4b
This issue is difficult to see, but you may find that groov is making more connections than necessary to your Modbus device. groov should make no more than two connections to a single Modbus device.
