KB86789
Published: June 30, 2017
PAC Display may crash when you try to replace a control engine using the Entire Project option
Version affected: R9.6d
Problem is fixed in version: R9.6e
PAC Display Configurator may crash if you select Entire Project when trying to replace a control engine using the Find and Replace dialog box (Edit > Replace > Search Scope).
For the search scope, select "All windows" or "Chosen graphics" instead of "Entire Project."
