KB86791
Published: August 1, 2017
SNAP PAC Redundancy Kit: Redundant controllers switch continuously and report "impaired" I/O unit
SNAP-PAC-S1-FM
Versions affected: PAC firmware R9.0a through R9.5d
Problem is fixed in version: FW R9.5e
When using the SNAP PAC Redundancy Kit, if an I/O unit is configured to use any port other than 2001 (the default port), both the primary and secondary controllers may log errors saying that the I/O unit is "impaired," and the system may switch continuously between controllers.
Use port 2001 (the default port) for all I/O units.
