KB86799
Published: August 1, 2017
SNAP PAC RESTful API: Controller resets if you write one or more spaces (instead of a JSON payload) to a variable
SNAP-PAC-S1-FM
SNAP-PAC-R1-FM
SNAP-PAC-R1-B
SNAP-PAC-R2-FM
Versions affected: PAC firmware R9.5a through R9.5d
Problem is fixed in version: FW R9.5e
When you use the SNAP PAC RESTful API to write to a variable, the
controller will unexpectedly reset if you send one or more spaces in the body of the request* instead of sending a JSON (key-value pair) payload.
*A request is a URL that follows the syntax for the SNAP PAC REST API. It's also known as an "endpoint."
