KB86803
Published: May 24, 2018
PAC Display: Can't select SuperTrend log file location after configuring Remote SuperTrend Logging
R9.6c through R9.6g
R10.0a
When configuring SuperTrends, if you configure remote logging (Configure > SuperTrend Remote Logging) before selecting the directory path for SuperTrend log files (SuperTrend Setup Dialog box, Setup tab > Log To), PAC Display doesn't display the Historical Log  File Configuration dialog box. This means you can't select a folder to store SuperTrend log files.
First configure the SuperTrend Log File, and then configure SuperTrend Remote Logging.
